本示例阐明了如何把标准的参数编辑器改变为任一自定义编辑器。
注意,从 v2010 vol 2 版开始,按照参数类型 (Parameter.Type 属性值) 来创建默认的编辑器。
要为参数提供自定义编辑器,则接管 XtraReport.ParametersRequestBeforeShow 事件,并把自定义编辑器指派到参数信息的 ParameterInfo.Editor 属性,其中参数信息被存储在 ParametersRequestEventArgs.ParametersInformation 属性返回的集合中。
在 DevExpress Code Central 数据库中可以找到完整的示例项目,网址是 http://www.devexpress.com/example=E390。 取决于目标平台类型 (ASP.NET、WinForms 等),可以在线运行本示例,或者下载自动可执行的示例。 |
using System; using DevExpress.XtraEditors; using DevExpress.XtraEditors.Controls; using DevExpress.XtraReports.UI; using DevExpress.XtraReports.Parameters; // ... private void XtraReport1_ParametersRequestBeforeShow(object sender, ParametersRequestEventArgs e) { CategoriesDataSet dataSet = new CategoriesDataSet(); CategoriesDataSetTableAdapters.CategoriesTableAdapter adapter = new CategoriesDataSetTableAdapters.CategoriesTableAdapter(); adapter.Fill(dataSet.Categories); foreach (ParameterInfo info in e.ParametersInformation) { if (info.Parameter.Name == "parameter1") { LookUpEdit lookUpEdit = new LookUpEdit(); lookUpEdit.Properties.DataSource = dataSet.Categories; lookUpEdit.Properties.DisplayMember = "CategoryName"; lookUpEdit.Properties.ValueMember = "CategoryID"; lookUpEdit.Properties.Columns.Add(new LookUpColumnInfo("CategoryName", 0, "Category Name")); info.Editor = lookUpEdit; } } } |
Imports System Imports DevExpress.XtraEditors Imports DevExpress.XtraEditors.Controls Imports DevExpress.XtraReports.UI Imports DevExpress.XtraReports.Parameters ' ... Private Sub XtraReport1_ParametersRequestBeforeShow(ByVal sender As System.Object, _ ByVal e As ParametersRequestEventArgs) Handles MyBase.ParametersRequestBeforeShow Dim DataSet As New CategoriesDataSet() Dim Adapter As New CategoriesDataSetTableAdapters.CategoriesTableAdapter() Adapter.Fill(DataSet.Categories) Dim Info As ParameterInfo For Each Info In e.ParametersInformation If Info.Parameter.Name = "Parameter1" Then Dim LookUpEdit As New LookUpEdit() LookUpEdit.Properties.DataSource = DataSet.Categories LookUpEdit.Properties.DisplayMember = "CategoryName" LookUpEdit.Properties.ValueMember = "CategoryID" LookUpEdit.Properties.Columns.Add(New _ LookUpColumnInfo("CategoryName", 0, "Category Name")) Info.Editor = LookUpEdit End If Next Info End Sub |
