下面的示例展示了如何把报表导出为 HTML 格式。 要完成此任务,需使用 XtraReport.ExportToHtml 方法。 此示例也演示了当报表被导出为 HTML 时,哪些特定的 HtmlExportOptions 可能被使用。
为了使此示例工作,首先需要 添加新报表 (命名为 XtraReport1) 到项目中,拖放一些报表控件到报表中,然后执行下面的代码 (例如,在窗体上任一按钮的 Button.Click 事件处理程序中)。 也要注意,如果想让结果文件自动被系统中默认的用于打开 *.html 文件的程序打开,那么可以调用在本例中也展示了的 StartProcess 方法。
在 DevExpress Code Central 数据库中可以找到完整的示例项目,网址是 http://www.devexpress.com/example=E117。 取决于目标平台类型 (ASP.NET、WinForms 等),可以在线运行本示例,或者下载自动可执行的示例。 |
using System.Drawing; using System.Diagnostics; using DevExpress.XtraPrinting; using DevExpress.XtraReports.UI; // ... private void button1_Click(object sender, EventArgs e) { // A path to export a report. string reportPath = "c:\\Test.html"; // Create a report instance. XtraReport1 report = new XtraReport1(); // Get its HTML export options. HtmlExportOptions htmlOptions = report.ExportOptions.Html; // Set HTML-specific export options. htmlOptions.CharacterSet = "UTF-8"; htmlOptions.RemoveSecondarySymbols = false; htmlOptions.Title = "Test Title"; // Set the pages to be exported, and page-by-page options. htmlOptions.ExportMode = HtmlExportMode.SingleFilePageByPage; htmlOptions.PageRange = "1, 3-5"; htmlOptions.PageBorderColor = Color.Blue; htmlOptions.PageBorderWidth = 3; // Export the report to HTML. report.ExportToHtml(reportPath); // Show the result. StartProcess(reportPath); } // Use this method if you want to automaically open // the created HTML file in the default program. public void StartProcess(string path) { Process process = new Process(); try { process.StartInfo.FileName = path; process.Start(); process.WaitForInputIdle(); } catch { } } |
Imports System.Drawing Imports System.Diagnostics Imports DevExpress.XtraPrinting Imports DevExpress.XtraReports.UI ' ... Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) _ Handles Button1.Click ' A path to export a report. Dim reportPath As String = "c:\\Test.html" ' Create a report instance. Dim report As New XtraReport1() ' Get its HTML export options. Dim htmlOptions As HtmlExportOptions = report.ExportOptions.Html ' Set HTML-specific export options. htmlOptions.CharacterSet = "UTF-8" htmlOptions.RemoveSecondarySymbols = False htmlOptions.Title = "Test Title" ' Set the pages to be exported, and page-by-page options. htmlOptions.ExportMode = HtmlExportMode.SingleFilePageByPage htmlOptions.PageRange = "1, 3-5" htmlOptions.PageBorderColor = Color.Blue htmlOptions.PageBorderWidth = 3 ' Export the report to HTML. report.ExportToHtml(reportPath) ' Show the result. StartProcess(reportPath) End Sub ' Use this method if you want to automaically open ' the created HTML file in the default program. Public Sub StartProcess(ByVal path As String) Dim process As New Process() Try process.StartInfo.FileName = path process.Start() process.WaitForInputIdle() Catch End Try End Sub |
