下面的示例演示了如何把报表导出为图像。 要完成此任务,需使用 XtraReport.ExportToImage 方法。 此示例也演示了当报表被导出为图像时,哪些特定的 ImageExportOptions 可能被使用。
为了使此示例工作,首先需要 添加新报表 (命名为 XtraReport1) 到项目中,拖放一些报表控件到报表中,然后执行下面的代码 (例如,在窗体上任一按钮的 Button.Click 事件处理程序中)。 也要注意,如果想让结果文件自动被系统中默认的用于打开 *.png 文件的程序打开,那么可以调用在本例中也展示了的 StartProcess 方法。
在 DevExpress Code Central 数据库中可以找到完整的示例项目,网址是 http://www.devexpress.com/example=E41。 取决于目标平台类型 (ASP.NET、WinForms 等),可以在线运行本示例,或者下载自动可执行的示例。 |
using System.Diagnostics; using System.Drawing.Imaging; using DevExpress.XtraPrinting; using DevExpress.XtraReports.UI; // ... private void button1_Click(object sender, EventArgs e) { // A path to export a report. string reportPath = "c:\\Test.png"; // Create a report instance. XtraReport1 report = new XtraReport1(); // Get its Image export options. ImageExportOptions imageOptions = report.ExportOptions.Image; // Set Image-specific export options. imageOptions.Format = ImageFormat.Png; // Export the report to Image. report.ExportToImage(reportPath); // Show the result. StartProcess(reportPath); } // Use this method if you want to automaically open // the created Image file in the default program. public void StartProcess(string path) { Process process = new Process(); try { process.StartInfo.FileName = path; process.Start(); process.WaitForInputIdle(); } catch { } } |
Imports System.Diagnostics Imports System.Drawing.Imaging Imports DevExpress.XtraPrinting Imports DevExpress.XtraReports.UI ' ... Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) _ Handles Button1.Click ' A path to export a report. Dim reportPath As String = "c:\\Test.png" ' Create a report instance. Dim report As New XtraReport1() ' Get its Image export options. Dim imageOptions As ImageExportOptions = report.ExportOptions.Image ' Set Image-specific export options. imageOptions.Format = ImageFormat.Png ' Export the report to Image. report.ExportToImage(reportPath) ' Show the result. StartProcess(reportPath) End Sub ' Use this method if you want to automaically open ' the created Image file in the default program. Public Sub StartProcess(ByVal path As String) Dim process As New Process() Try process.StartInfo.FileName = path process.Start() process.WaitForInputIdle() Catch End Try End Sub |
