在 DevExpress Code Central 数据库中可以找到完整的示例项目,网址是 http://www.devexpress.com/example=E2664。 取决于目标平台类型 (ASP.NET、WinForms 等),可以在线运行本示例,或者下载自动可执行的示例。 |
这个示例展示了在运行时刻如何通过 ChartControl.AppearanceName、ChartControl.PaletteName 和 ChartControl.PaletteBaseColorNumber 属性来定制图表的外观。
注意,可以通过 ChartControl.IndicatorsPaletteName 属性,为绘制图表中所有可用的指标线而指定单独的调色板。
(Form1.cs) using System; using System.Windows.Forms; using DevExpress.XtraCharts; // ... private void Form1_Load(object sender, EventArgs e) { // Create an empty chart. ChartControl barChart = new ChartControl(); // Create a series and add points to it. Series series1 = new Series("Bar Series", ViewType.Bar); series1.Points.Add(new SeriesPoint("A", new double[] { 10 })); series1.Points.Add(new SeriesPoint("B", new double[] { 12 })); series1.Points.Add(new SeriesPoint("C", new double[] { 14 })); series1.Points.Add(new SeriesPoint("D", new double[] { 17 })); // Create an indicator (e.g. Regression Line), // and add it to the series' collection. RegressionLine myLine = new RegressionLine(ValueLevel.Value); ((SideBySideBarSeriesView)series1.View).Indicators.Add(myLine); // Add the series to the chart. barChart.Series.Add(series1); // Define the chart's appearance and palette. barChart.AppearanceName = "Dark"; barChart.PaletteName = "Opulent"; barChart.PaletteBaseColorNumber = 5; // Define a separate palette for the chart's indicators. barChart.IndicatorsPaletteName = "Default"; // Add the chart to the form. barChart.Dock = DockStyle.Fill; this.Controls.Add(barChart); } |
(Form1.vb) Imports System Imports System.Windows.Forms Imports DevExpress.XtraCharts ' ... Private Sub Form1_Load(ByVal sender As Object, _ ByVal e As EventArgs) Handles MyBase.Load ' Create an empty chart. Dim barChart As New ChartControl() ' Create a series and add points to it. Dim series1 As New Series("Bar Series", ViewType.Bar) series1.Points.Add(New SeriesPoint("A", New Double() { 10 })) series1.Points.Add(New SeriesPoint("B", New Double() { 12 })) series1.Points.Add(New SeriesPoint("C", New Double() { 14 })) series1.Points.Add(New SeriesPoint("D", New Double() { 17 })) ' Create an indicator (e.g. Regression Line), ' and add it to the series' collection. Dim myLine As New RegressionLine(ValueLevel.Value) CType(series1.View, SideBySideBarSeriesView).Indicators.Add(myLine) ' Add the series to the chart. barChart.Series.Add(series1) ' Define the chart's appearance and palette. barChart.AppearanceName = "Dark" barChart.PaletteName = "Opulent" barChart.PaletteBaseColorNumber = 5 ' Define a separate palette for the chart's indicators. barChart.IndicatorsPaletteName = "Default" ' Add the chart to the form. barChart.Dock = DockStyle.Fill Me.Controls.Add(barChart) End Sub |
在下面的插图中显示了结果。
在 DevExpress Code Central 数据库中可以找到完整的示例项目,网址是 http://www.devexpress.com/example=E1179。 取决于目标平台类型 (ASP.NET、WinForms 等),可以在线运行本示例,或者下载自动可执行的示例。 |
