这个示例展示了如何创建某种类型 (弧形、扇形或回撤线) 的 斐波那契指标线,并把它添加到财务系列。 为了完成此任务,创建了 FibonacciIndicator 类的一个实例,并指定它的 FibonacciIndicator.Kind 属性。 然后,把此指标线添加到由 XYDiagram2DSeriesViewBase.Indicators 属性返回的系列的指标线集合中。
在 DevExpress Code Central 数据库中可以找到完整的示例项目,网址是 http://www.devexpress.com/example=E966。 取决于目标平台类型 (ASP.NET、WinForms 等),可以在线运行本示例,或者下载自动可执行的示例。 |
using System; using System.Drawing; using System.Windows.Forms; using DevExpress.XtraCharts; // ... private void Form1_Load(object sender, EventArgs e) { // Create a series. Series series = new Series("Stock", ViewType.Stock); series.ArgumentScaleType = ScaleType.DateTime; // Populate the series with data. AddPoints(series); // Add it to the chart. this.chartControl1.Series.Add(series); // Adjust the chart's appearance. XYDiagram diagram = (XYDiagram)this.chartControl1.Diagram; diagram.AxisY.Range.AlwaysShowZeroLevel = false; diagram.AxisX.Label.Staggered = true; series.Label.Visible = false; } private void AddPoints(Series series) { series.Points.AddRange(new SeriesPoint[] { new SeriesPoint(new DateTime(2007, 12, 24), new object[] {110.55, 112, 111.2, 111.65}), new SeriesPoint(new DateTime(2007, 12, 26), new object[] {110.9, 112.19, 110.9, 111.56}), new SeriesPoint(new DateTime(2007, 12, 27), new object[] {109.49, 111.3, 110.53, 109.6}), new SeriesPoint(new DateTime(2007, 12, 28), new object[] {109.108, 110.76, 110.76, 110.09}), new SeriesPoint(new DateTime(2007, 12, 31), new object[] {107.26, 110, 109.51, 108.1}), new SeriesPoint(new DateTime(2008, 1, 2), new object[] {104.17, 108.99, 108.99, 104.69}), new SeriesPoint(new DateTime(2008, 1, 3), new object[] {103.98, 105.57, 104.83, 104.9}), new SeriesPoint(new DateTime(2008, 1, 4), new object[] {100.48, 103.95, 103.95, 101.13}), new SeriesPoint(new DateTime(2008, 1, 7), new object[] {99.03, 101, 100.25, 100.05}), new SeriesPoint(new DateTime(2008, 1, 8), new object[] {97.17, 100.38, 100.05, 97.59}), new SeriesPoint(new DateTime(2008, 1, 9), new object[] {97.16, 99.15, 97.76, 98.31}), new SeriesPoint(new DateTime(2008, 1, 10), new object[] {97.15, 100.86, 97.39, 99.92}), new SeriesPoint(new DateTime(2008, 1, 11), new object[] {97.09, 99.46, 99.2, 97.67}), new SeriesPoint(new DateTime(2008, 1, 14), new object[] {101.33, 105.59, 105.01, 102.93}), new SeriesPoint(new DateTime(2008, 1, 15), new object[] {101.23, 104.04, 102.03, 101.83}), new SeriesPoint(new DateTime(2008, 1, 16), new object[] {100.14, 102.86, 100.14, 101.63}), new SeriesPoint(new DateTime(2008, 1, 17), new object[] {100.05, 103.45, 102, 101.1}), new SeriesPoint(new DateTime(2008, 1, 18), new object[] {102.5, 106.72, 106.72, 103.4}), new SeriesPoint(new DateTime(2008, 1, 22), new object[] {98.55, 103.09, 98.55, 101.22}), new SeriesPoint(new DateTime(2008, 1, 23), new object[] {98.5, 106.335, 99.63, 106.1}), new SeriesPoint(new DateTime(2008, 1, 24), new object[] {104.68, 107.51, 106.38, 106.91}), new SeriesPoint(new DateTime(2008, 1, 25), new object[] {104.1, 107.79, 107.79, 104.52}), new SeriesPoint(new DateTime(2008, 1, 28), new object[] {103.83, 105.77, 104.44, 104.98}), new SeriesPoint(new DateTime(2008, 1, 29), new object[] {104.6, 106.8, 105.5, 106.1}), new SeriesPoint(new DateTime(2008, 1, 30), new object[] {104.855, 107.65, 105.85, 105.65}), new SeriesPoint(new DateTime(2008, 1, 31), new object[] {103.7, 107.97, 104.21, 107.11}) }); } private void btnArcs_Click(object sender, EventArgs e) { AddIndicator(chartControl1.Series[0], FibonacciIndicatorKind.FibonacciArcs); } private void btnFans_Click(object sender, EventArgs e) { AddIndicator(chartControl1.Series[0], FibonacciIndicatorKind.FibonacciFans); } private void btnRetracements_Click(object sender, EventArgs e) { AddIndicator(chartControl1.Series[0], FibonacciIndicatorKind.FibonacciRetracement); } private void AddIndicator(Series ser, FibonacciIndicatorKind kind) { // Get a collection of indicators. IndicatorCollection indicators = ((StockSeriesView)ser.View).Indicators; // Clear it. indicators.Clear(); // Add a new indicator to it. indicators.Add(CreateIndicator(kind, new DateTime(2007, 12, 27), new DateTime(2008, 1, 17), ValueLevel.High)); } private FibonacciIndicator CreateIndicator(FibonacciIndicatorKind kind, DateTime arg1, DateTime arg2, ValueLevel level) { // Create the Fibonacci Indicator of the specified kind. FibonacciIndicator fi = new FibonacciIndicator(kind); // Specify its start and end points. fi.Point1.Argument = arg1; fi.Point1.ValueLevel = level; fi.Point2.Argument = arg2; fi.Point2.ValueLevel = level; // Select the name. switch (fi.Kind) { case FibonacciIndicatorKind.FibonacciArcs: { fi.Name = "Arcs"; break; } case FibonacciIndicatorKind.FibonacciFans: { fi.Name = "Fans"; break; } case FibonacciIndicatorKind.FibonacciRetracement: { fi.Name = "Retracement"; break; } } // Make all its levels visible. fi.ShowLevel23_6 = true; fi.ShowLevel76_4 = true; fi.ShowLevel0 = true; fi.ShowLevel100 = true; fi.ShowAdditionalLevels = true; // Customize its appearance. fi.BaseLevelColor = Color.Green; fi.BaseLevelLineStyle.DashStyle = DashStyle.Dash; return fi; } |
Imports System Imports System.Drawing Imports System.Windows.Forms Imports DevExpress.XtraCharts ' ... Private Sub Form1_Load(ByVal sender As Object, _ ByVal e As EventArgs) Handles MyBase.Load ' Create a series. Dim series As New Series("Stock", ViewType.Stock) series.ArgumentScaleType = ScaleType.DateTime ' Populate the series with data. AddPoints(series) ' Add it to the chart. Me.chartControl1.Series.Add(series) ' Adjust the chart's appearance. Dim diagram As XYDiagram = CType(Me.chartControl1.Diagram, XYDiagram) diagram.AxisY.Range.AlwaysShowZeroLevel = False diagram.AxisX.Label.Staggered = True series.Label.Visible = False End Sub Private Sub AddPoints(ByVal series As Series) series.Points.AddRange(New SeriesPoint() { _ New SeriesPoint(New DateTime(2007, 12, 24), New Object() {110.55, 112, 111.2, 111.65}), _ New SeriesPoint(New DateTime(2007, 12, 26), New Object() {110.9, 112.19, 110.9, 111.56}), _ New SeriesPoint(New DateTime(2007, 12, 27), New Object() {109.49, 111.3, 110.53, 109.6}), _ New SeriesPoint(New DateTime(2007, 12, 28), New Object() {109.108, 110.76, 110.76, 110.09}), _ New SeriesPoint(New DateTime(2007, 12, 31), New Object() {107.26, 110, 109.51, 108.1}), _ New SeriesPoint(New DateTime(2008, 1, 2), New Object() {104.17, 108.99, 108.99, 104.69}), _ New SeriesPoint(New DateTime(2008, 1, 3), New Object() {103.98, 105.57, 104.83, 104.9}), _ New SeriesPoint(New DateTime(2008, 1, 4), New Object() {100.48, 103.95, 103.95, 101.13}), _ New SeriesPoint(New DateTime(2008, 1, 7), New Object() {99.03, 101, 100.25, 100.05}), _ New SeriesPoint(New DateTime(2008, 1, 8), New Object() {97.17, 100.38, 100.05, 97.59}), _ New SeriesPoint(New DateTime(2008, 1, 9), New Object() {97.16, 99.15, 97.76, 98.31}), _ New SeriesPoint(New DateTime(2008, 1, 10), New Object() {97.15, 100.86, 97.39, 99.92}), _ New SeriesPoint(New DateTime(2008, 1, 11), New Object() {97.09, 99.46, 99.2, 97.67}), _ New SeriesPoint(New DateTime(2008, 1, 14), New Object() {101.33, 105.59, 105.01, 102.93}), _ New SeriesPoint(New DateTime(2008, 1, 15), New Object() {101.23, 104.04, 102.03, 101.83}), _ New SeriesPoint(New DateTime(2008, 1, 16), New Object() {100.14, 102.86, 100.14, 101.63}), _ New SeriesPoint(New DateTime(2008, 1, 17), New Object() {100.05, 103.45, 102, 101.1}), _ New SeriesPoint(New DateTime(2008, 1, 18), New Object() {102.5, 106.72, 106.72, 103.4}), _ New SeriesPoint(New DateTime(2008, 1, 22), New Object() {98.55, 103.09, 98.55, 101.22}), _ New SeriesPoint(New DateTime(2008, 1, 23), New Object() {98.5, 106.335, 99.63, 106.1}), _ New SeriesPoint(New DateTime(2008, 1, 24), New Object() {104.68, 107.51, 106.38, 106.91}), _ New SeriesPoint(New DateTime(2008, 1, 25), New Object() {104.1, 107.79, 107.79, 104.52}), _ New SeriesPoint(New DateTime(2008, 1, 28), New Object() {103.83, 105.77, 104.44, 104.98}), _ New SeriesPoint(New DateTime(2008, 1, 29), New Object() {104.6, 106.8, 105.5, 106.1}), _ New SeriesPoint(New DateTime(2008, 1, 30), New Object() {104.855, 107.65, 105.85, 105.65}), _ New SeriesPoint(New DateTime(2008, 1, 31), New Object() {103.7, 107.97, 104.21, 107.11}) }) End Sub Private Sub btnArcs_Click(ByVal sender As Object, _ ByVal e As EventArgs) Handles btnArcs.Click AddIndicator(chartControl1.Series(0), FibonacciIndicatorKind.FibonacciArcs) End Sub Private Sub btnFans_Click(ByVal sender As Object, _ ByVal e As EventArgs) Handles btnFans.Click AddIndicator(chartControl1.Series(0), FibonacciIndicatorKind.FibonacciFans) End Sub Private Sub btnRetracements_Click(ByVal sender As Object, _ ByVal e As EventArgs) Handles btnRetracements.Click AddIndicator(chartControl1.Series(0), FibonacciIndicatorKind.FibonacciRetracement) End Sub Private Sub AddIndicator(ByVal ser As Series, _ ByVal kind As FibonacciIndicatorKind) ' Get a collection of indicators. Dim indicators As IndicatorCollection = (CType(ser.View, StockSeriesView)).Indicators ' Clear it. indicators.Clear() ' Add a new indicator to it. indicators.Add(CreateIndicator(kind, New DateTime(2007, 12, 27), _ New DateTime(2008, 1, 17), ValueLevel.High)) End Sub Private Function CreateIndicator(ByVal kind As FibonacciIndicatorKind, ByVal arg1 As DateTime, _ ByVal arg2 As DateTime, ByVal level As ValueLevel) As FibonacciIndicator ' Create the Fibonacci Indicator of the specified kind. Dim fi As New FibonacciIndicator(kind) ' Specify its start and end points. fi.Point1.Argument = arg1 fi.Point1.ValueLevel = level fi.Point2.Argument = arg2 fi.Point2.ValueLevel = level ' Select the name. Select Case fi.Kind Case FibonacciIndicatorKind.FibonacciArcs fi.Name = "Arcs" Exit Select Case FibonacciIndicatorKind.FibonacciFans fi.Name = "Fans" Exit Select Case FibonacciIndicatorKind.FibonacciRetracement fi.Name = "Retracement" Exit Select End Select ' Make all its levels visible. fi.ShowLevel23_6 = True fi.ShowLevel76_4 = True fi.ShowLevel0 = True fi.ShowLevel100 = True fi.ShowAdditionalLevels = True ' Customize its appearance. fi.BaseLevelColor = Color.Green fi.BaseLevelLineStyle.DashStyle = DashStyle.Dash Return fi End Function |
