Note注意
重要说明: .NET Client Profile Framework 不支持此功能。 要在最终用户的机器上使用此功能,则必须安装完整的 .NET Framework。 更多信息,请参阅 Windows 窗体部署 文档中的 关于 .NET Framework 4.0 Client Profile 的重要说明 小节。
这个示例展示了如何重命名 最终用户设计器 中的 工具箱 项。
要这样做,则接管 XRDesignMdiController.DesignPanelLoaded 事件,从报表设计器获取 System.Drawing.Design.IToolboxService 对象,并按需要定制工具箱项的集合。
下列代码把一个前缀添加到所有工具箱项的名称之前。
using System;
using System.Windows.Forms;
using System.Drawing.Design;
using DevExpress.XtraReports.UserDesigner;
private void button1_Click(object sender, EventArgs e) {
    // Create a new End-User Designer.
    XRDesignForm designForm = new XRDesignForm();
    // Handle the DesignPanelLoaded event.
    designForm.DesignMdiController.DesignPanelLoaded +=
        new DesignerLoadedEventHandler(DesignMdiController_DesignPanelLoaded);
    // Load the report into the designer.
    designForm.OpenReport(new XtraReport1());
    // Show the End-User Designer window.
    designForm.Show();
private void DesignMdiController_DesignPanelLoaded(object sender, DesignerLoadedEventArgs e) {
    // Get the toolbox service.
    IToolboxService ts = (IToolboxService)e.DesignerHost.GetService(typeof(IToolboxService));
    // Get a collection of toolbox items.
    ToolboxItemCollection coll = ts.GetToolboxItems();
    // Iterate through toolbox items.
    foreach (ToolboxItem item in coll) {
        // Add the "Cool" prefix to all toolbox item names.
        item.DisplayName = "Cool " + item.DisplayName;
Imports System
Imports System.Windows.Forms
Imports System.Drawing.Design
Imports DevExpress.XtraReports.UserDesigner
Private Sub button1_Click(ByVal sender As Object, ByVal e As EventArgs) Handles button1.Click
    ' Create a new End-User Designer.
    Dim designForm As New XRDesignForm()
    ' Handle the DesignPanelLoaded event.
    AddHandler designForm.DesignMdiController.DesignPanelLoaded, _
        AddressOf DesignMdiController_DesignPanelLoaded
    ' Load the report into the designer.
    designForm.OpenReport(New XtraReport1())
    ' Show the End-User Designer window.
    designForm.Show()
Private Sub DesignMdiController_DesignPanelLoaded(ByVal sender As Object, _
ByVal e As DesignerLoadedEventArgs)
    ' Get the toolbox service.
    Dim ts As IToolboxService = _
        CType(e.DesignerHost.GetService(GetType(IToolboxService)), IToolboxService)
    ' Get a collection of toolbox items.
    Dim coll As ToolboxItemCollection = ts.GetToolboxItems()
    ' Iterate through toolbox items.
    For Each item As ToolboxItem In coll
        ' Add the "Cool" prefix to all toolbox item names.
        item.DisplayName = "Cool " & item.DisplayName
    Next item
CodeCentralShow Me
在 DevExpress Code Central 数据库中可以找到完整的示例项目,网址是 http://www.devexpress.com/example=E2477。 取决于目标平台类型 (ASP.NET、WinForms 等),可以在线运行本示例,或者下载自动可执行的示例。
