这个示例展示了如何在图表中绘制 系列 时,实现自定义绘制。 要这样做,则应接管 ChartControl.CustomDrawSeries 事件,然后可以使用事件的参数来改变某些绘制参量。
Note注意
对于 WebChartControl,应该接管 WebChartControl.CustomDrawSeries 事件来完成此任务。
using DevExpress.XtraCharts;
private void chartControl1_CustomDrawSeries(object sender,
CustomDrawSeriesEventArgs e) {
   // Find all Bar Series by their view type,
   // and fill them with Aqua color.
   if (e.Series.View is BarSeriesView)
      e.SeriesDrawOptions.Color = Color.Aqua;
   // Find the series by its name,
   // and change its line style to dash-dot-dot.
   // (Here it's assumed that the series view type is LineSeriesView).
   if (e.Series.Name == "Line Series")
      ((LineDrawOptions)e.SeriesDrawOptions).LineStyle.DashStyle =
      DashStyle.DashDotDot;
   // Find all Point Series by the type of its DrawOptions,
   // and change their marker kind to diamond.
   if (e.SeriesDrawOptions.GetType() == typeof(PointDrawOptions))
      ((PointDrawOptions)e.SeriesDrawOptions).Marker.Kind =
      MarkerKind.Diamond;
Imports DevExpress.XtraCharts
Private Sub OnCustomDrawSeries(sender As Object, e As CustomDrawSeriesEventArgs) _
Handles ChartControl1.CustomDrawSeries
   ' Find all Bar Series by their view type, and fill them with Aqua color.
   If TypeOf e.Series.View Is BarSeriesView Then
   End If
   ' Find the series by its name, and change its line style to dash-dot-dot.
   ' (Here it's assumed that the series view type is LineSeriesView).
   If e.Series.Name = "Line Series" Then
      CType(e.SeriesDrawOptions, LineDrawOptions).LineStyle.DashStyle = DashStyle.DashDotDot
   End If
   ' Find all Point Series by the type of its DrawOptions,
   ' and change their marker kind to diamond.
   If e.SeriesDrawOptions.GetType() Is GetType(PointDrawOptions) Then
      CType(e.SeriesDrawOptions, PointDrawOptions).Marker.Kind = MarkerKind.Diamond
   End If
