这个示例展示了如何在图表中绘制 系列点 时,实现自定义绘制。 要这样做,则应接管 ChartControl.CustomDrawSeriesPoint 事件,然后可以使用事件的参数来改变某些绘制参量。
对于 WebChartControl,应该接管 WebChartControl.CustomDrawSeriesPoint 事件来完成此任务。 |
using DevExpress.XtraCharts; // ... private void chartControl1_CustomDrawSeriesPoint(object sender, CustomDrawSeriesPointEventArgs e) { // These changes will be applied to Bar Series only. BarDrawOptions drawOptions = e.SeriesDrawOptions as BarDrawOptions; if (drawOptions == null) return; // Get the fill options for the series point. drawOptions.FillStyle.FillMode = FillMode.Gradient; RectangleGradientFillOptions options = drawOptions.FillStyle.Options as RectangleGradientFillOptions; if (options == null) return; // Get the value at the current series point. double val = e.SeriesPoint[0]; // If the value is less than 2.5, then fill the bar with green colors. if (val < 2.5) { options.Color2 = Color.FromArgb(154, 196, 84); drawOptions.Color = Color.FromArgb(81, 137, 3); drawOptions.Border.Color = Color.FromArgb(100, 39, 91, 1); } // ... if the value is less than 5.5, then fill the bar with yellow colors. else if (val < 5.5) { options.Color2 = Color.FromArgb(254, 233, 124); drawOptions.Color = Color.FromArgb(249, 170, 15); drawOptions.Border.Color = Color.FromArgb(60, 165, 73, 5); } // ... if the value is greater, then fill the bar with red colors. else { options.Color2 = Color.FromArgb(242, 143, 112); drawOptions.Color = Color.FromArgb(199, 57 ,12); drawOptions.Border.Color = Color.FromArgb(100, 155, 26, 0); } } |
Imports DevExpress.XtraCharts ' ... Private Sub OnCustomDrawSeriesPoint(ByVal sender As Object, _ ByVal e As CustomDrawSeriesPointEventArgs) _ Handles chartControl1.CustomDrawSeriesPoint ' These changes will be applied to Bar Series only. Dim drawOptions = CType(e.SeriesDrawOptions, BarDrawOptions) If drawOptions Is Nothing Then Return End If ' Get the fill options for the series point. drawOptions.FillStyle.FillMode = FillMode.Gradient Dim options = CType(drawOptions.FillStyle.Options, RectangleGradientFillOptions) If options Is Nothing Then Return End If ' Get the value at the current series point. Dim val As Double = e.SeriesPoint(0) ' If the value is less than 2.5, then fill the bar with green colors. If val < 2.5 Then options.Color2 = Color.FromArgb(154, 196, 84) drawOptions.Color = Color.FromArgb(81, 137, 3) drawOptions.Border.Color = Color.FromArgb(100, 39, 91, 1) ' ... if the value is less than 5.5, then fill the bar with yellow colors. Else If val < 5.5 Then options.Color2 = Color.FromArgb(254, 233, 124) drawOptions.Color = Color.FromArgb(249, 170, 15) drawOptions.Border.Color = Color.FromArgb(60, 165, 73, 5) ' ... if the value is greater, then fill the bar with red colors. Else options.Color2 = Color.FromArgb(242, 143, 112) drawOptions.Color = Color.FromArgb(199, 57, 12) drawOptions.Border.Color = Color.FromArgb(100, 155, 26, 0) End If End If End Sub |
