这个示例展示了如何改变 最终用户设计器 中的菜单项和 智能标记 项的可视性。 要这样做,需要使用 XRDesignPanel.SetCommandVisibility 方法。
下列代码隐藏了 New with Wizard(使用向导新建)... 菜单项和报表智能标记的 Design in Report Wizard(在报表向导中设计)... 操作项。 在 ReportCommand 枚举中列出了所有可用的报表命令。
using System; using System.Windows.Forms; using DevExpress.XtraReports.UserDesigner; //... private void button1_Click(object sender, EventArgs e) { // Create an End-User Designer form instance. XRDesignForm designForm = new XRDesignForm(); // Load a new blank report into it. designForm.OpenReport(new XtraReport1()); // Hide the "New with Wizard..." item on the File menu, // and the "Design in Report Wizard..." item in the report's smart tag. designForm.ActiveDesignPanel.SetCommandVisibility(ReportCommand.NewReportWizard, CommandVisibility.None); designForm.ActiveDesignPanel.SetCommandVisibility(ReportCommand.VerbReportWizard, CommandVisibility.None); // Show the End-User Designer form. designForm.Show(); } |
Imports System Imports System.Windows.Forms Imports DevExpress.XtraReports.UserDesigner '... Private Sub button1_Click(ByVal sender As Object, _ ByVal e As EventArgs) Handles button1.Click ' Create an End-User Designer form instance. Dim designForm As New XRDesignForm() ' Load a new blank report into it. designForm.OpenReport(New XtraReport1()) ' Hide the "New with Wizard..." item on the File menu, ' and the "Design in Report Wizard..." item in the report's smart tag. designForm.ActiveDesignPanel.SetCommandVisibility(ReportCommand.NewReportWizard, _ CommandVisibility.None) designForm.ActiveDesignPanel.SetCommandVisibility(ReportCommand.VerbReportWizard, _ CommandVisibility.None) ' Show the End-User Designer form. designForm.Show() End Sub |
在 DevExpress Code Central 数据库中可以找到完整的示例项目,网址是 http://www.devexpress.com/example=E203。 取决于目标平台类型 (ASP.NET、WinForms 等),可以在线运行本示例,或者下载自动可执行的示例。 |
