关于在最终用户设计器中更复杂的报表保存方法,请参阅 如何: 实现自定义报表存储器。 |
这个示例展示了如何重写并定制 最终用户设计器 中的保存功能。 这是有用的,例如,如果项目中的所有报表都应该通过流被保存在数据库中、然后从数据库取回,并且需要自动完成所有这些操作,而不迫使最终用户除了单击 保存 (或 另存为) 工具栏按钮以外、还执行其他操作。
在本例中,当最终用户关闭报表设计器时,将使用自定义保存程序来自动保存报表。
要完成此任务,则接管 ReportCommand.SaveFile 和 ReportCommand.SaveFileAs 命令 (如果有必要,也可接管 ReportCommand.Closing 命令)。 注意,要防止标准的保存程序被调用,则只需要启用 handled 属性。
下列代码展示了如何完成此任务。
using DevExpress.XtraReports.UserDesigner; // ... private void button1_Click(object sender, EventArgs e) { // Create a design form and get its panel. XRDesignForm form = new XRDesignForm(); // Open an empty report in the form. form.OpenReport(new XtraReport1()); // Get the active Design Panel. XRDesignPanel panel = form.ActiveDesignPanel; // Add a new command handler which saves a report in a custom way. panel.AddCommandHandler(new SaveCommandHandler(panel)); // Show the form. form.ShowDialog(); panel.CloseReport(); } public class SaveCommandHandler : ICommandHandler { XRDesignPanel panel; public SaveCommandHandler(XRDesignPanel panel) { this.panel = panel; } public virtual void HandleCommand(ReportCommand command, object[] args, ref bool handled) { if (!CanHandleCommand(command)) return; // Save a report. Save(); // Set handled to true to avoid the standard saving procedure to be called. handled = true; } public virtual bool CanHandleCommand(ReportCommand command) { // This handler is used for SaveFile, SaveFileAs and Closing commands. return command == ReportCommand.SaveFile || command == ReportCommand.SaveFileAs || command == ReportCommand.Closing; } void Save() { // Write your custom saving here. // ... // For instance: panel.Report.SaveLayout("c:\\report1.repx"); // Prevent the "Report has been changed" dialog from being shown. panel.ReportState = ReportState.Saved; } } |
Imports DevExpress.XtraReports.UserDesigner ' ... Private Sub button1_Click(ByVal sender As Object, _ ByVal e As EventArgs) Handles button1.Click ' Create a design form and get its panel. Dim form As New XRDesignForm() ' Open an empty report in the form. form.OpenReport(New XtraReport1()) ' Get the active Design Panel. Dim panel As XRDesignPanel = form.ActiveDesignPanel ' Add a new command handler which saves a report in a custom way. panel.AddCommandHandler(New SaveCommandHandler(panel)) ' Show the form. form.ShowDialog() panel.CloseReport() End Sub Public Class SaveCommandHandler Implements ICommandHandler Private panel As XRDesignPanel Public Sub New(ByVal panel As XRDesignPanel) Me.panel = panel End Sub Public Overridable Sub HandleCommand(ByVal command As ReportCommand, _ ByVal args() As Object, ByRef handled As Boolean) Implements ICommandHandler.HandleCommand If (Not CanHandleCommand(command)) Then Return End If ' Save a report. Save() ' Set handled to true to avoid the standard saving procedure to be called. handled = True End Sub Public Overridable Function CanHandleCommand(ByVal command As ReportCommand) As Boolean _ Implements ICommandHandler.CanHandleCommand ' This handler is used for SaveFile, SaveFileAs and Closing commands. Return command = ReportCommand.SaveFile OrElse command = ReportCommand.SaveFileAs OrElse _ command = ReportCommand.Closing End Function Private Sub Save() ' Write your custom saving here. ' ... ' For instance: panel.Report.SaveLayout("c:\report1.repx") ' Prevent the "Report has been changed" dialog from being shown. panel.ReportState = ReportState.Saved End Sub End Class |
