下面的示例演示了如何在运行时刻使用系列模板把图表绑定到数据。 它使用与 设计时刻示例 相同的方法,但是在代码中生成了另一个数据表来简化示例。 要使本示例正确工作,则不要忘了把所有 必需的程序集 包含到项目的“引用”列表中。
using System; using System.Data; using System.Windows.Forms; using DevExpress.XtraCharts; // ... private DataTable CreateChartData() { // Create an empty table. DataTable table = new DataTable("Table1"); // Add three columns to the table. table.Columns.Add("Month", typeof(String)); table.Columns.Add("Section", typeof(String)); table.Columns.Add("Value", typeof(Int32)); // Add data rows to the table. table.Rows.Add(new object[] { "Jan", "Section1", 10 }); table.Rows.Add(new object[] { "Jan", "Section2", 20 }); table.Rows.Add(new object[] { "Feb", "Section1", 20 }); table.Rows.Add(new object[] { "Feb", "Section2", 30 }); table.Rows.Add(new object[] { "March", "Section1", 15 }); table.Rows.Add(new object[] { "March", "Section2", 25 }); return table; } private void Form1_Load(object sender, EventArgs e) { // Create a chart. ChartControl chart = new ChartControl(); // Generate a data table and bind the chart to it. chart.DataSource = CreateChartData(); // Specify data members to bind the chart's series template. chart.SeriesDataMember = "Month"; chart.SeriesTemplate.ArgumentDataMember = "Section"; chart.SeriesTemplate.ValueDataMembers.AddRange(new string[] {"Value"}); // Specify the template's series view. chart.SeriesTemplate.View = new StackedBarSeriesView(); // Specify the template's name prefix. chart.SeriesNameTemplate.BeginText = "Month: "; // Dock the chart into its parent, and add it to the current form. chart.Dock = DockStyle.Fill; this.Controls.Add(chart); } |
Imports System Imports System.Data Imports System.Windows.Forms Imports DevExpress.XtraCharts ' ... Private Function CreateChartData() As DataTable ' Create an empty table. Dim Table As New DataTable("Table1") ' Add three columns to the table. Table.Columns.Add("Month", GetType([String])) Table.Columns.Add("Section", GetType([String])) Table.Columns.Add("Value", GetType(Int32)) ' Add data rows to the table. Table.Rows.Add(New Object() {"Jan", "Section1", 10}) Table.Rows.Add(New Object() {"Jan", "Section2", 20}) Table.Rows.Add(New Object() {"Feb", "Section1", 20}) Table.Rows.Add(New Object() {"Feb", "Section2", 30}) Table.Rows.Add(New Object() {"March", "Section1", 15}) Table.Rows.Add(New Object() {"March", "Section2", 25}) Return Table End Function Private Sub Form1_Load(ByVal sender As Object, ByVal e As EventArgs) _ Handles MyBase.Load ' Create a chart. Dim Chart As New ChartControl() ' Generate a data table and bind the chart to it. Chart.DataSource = CreateChartData() ' Specify data members to bind the chart's series template. Chart.SeriesDataMember = "Month" Chart.SeriesTemplate.ArgumentDataMember = "Section" Chart.SeriesTemplate.ValueDataMembers.AddRange(New String() {"Value"}) ' Specify the template's series view. Chart.SeriesTemplate.View = New StackedBarSeriesView() ' Specify the template's name prefix. Chart.SeriesNameTemplate.BeginText = "Month: " ' Dock the chart into its parent, and add it to the current form. Chart.Dock = DockStyle.Fill Me.Controls.Add(Chart) End Sub |
在 DevExpress Code Central 数据库中可以找到完整的示例项目,网址是 http://www.devexpress.com/example=E3。 取决于目标平台类型 (ASP.NET、WinForms 等),可以在线运行本示例,或者下载自动可执行的示例。 |
