要访问轴,则应该把图表的 图象 对象转换为所需的图象类型。 然后,使用 Axis2D.Tickmarks 和 AxisBase.GridLines 属性来访问相应的元素。 要指定 minor 刻度 (网格线) 的数目,则使用 AxisBase.MinorCount 属性。
// Cast the chart's diagram to the XYDiagram type, to access its axes. XYDiagram diagram = (XYDiagram)chartControl1.Diagram; // Customize the appearance of the axes' tickmarks. diagram.AxisX.Tickmarks.CrossAxis = true; diagram.AxisX.Tickmarks.Length = 5; diagram.AxisX.Tickmarks.Thickness = 2; diagram.AxisY.Tickmarks.Visible = false; diagram.AxisY.Tickmarks.MinorVisible = false; diagram.AxisX.Tickmarks.MinorLength = 3; diagram.AxisX.Tickmarks.MinorThickness = 1; diagram.AxisX.MinorCount = 2; diagram.AxisY.MinorCount = 4; // Customize the appearance of the axes' grid lines. diagram.AxisX.GridLines.Visible = false; diagram.AxisX.GridLines.MinorVisible = false; diagram.AxisY.GridLines.Visible = true; diagram.AxisY.GridLines.MinorVisible = true; diagram.AxisY.GridLines.Color = Color.Red; diagram.AxisY.GridLines.LineStyle.DashStyle = DashStyle.Solid; diagram.AxisY.GridLines.LineStyle.Thickness = 2; diagram.AxisY.GridLines.MinorColor = Color.Blue; diagram.AxisY.GridLines.MinorLineStyle.DashStyle = DashStyle.Dash; diagram.AxisY.GridLines.MinorLineStyle.Thickness = 1; |
' Cast the chart's diagram to the XYDiagram type, to access its axes. Dim diagram As XYDiagram = CType(chartControl1.Diagram, XYDiagram) ' Customize the appearance of the axes' tickmarks. diagram.AxisX.Tickmarks.CrossAxis = True diagram.AxisX.Tickmarks.Length = 5 diagram.AxisX.Tickmarks.Thickness = 2 diagram.AxisY.Tickmarks.Visible = False diagram.AxisY.Tickmarks.MinorVisible = False diagram.AxisX.Tickmarks.MinorLength = 3 diagram.AxisX.Tickmarks.MinorThickness = 1 diagram.AxisX.MinorCount = 2 diagram.AxisY.MinorCount = 4 ' Customize the appearance of the axes' grid lines. diagram.AxisX.GridLines.Visible = False diagram.AxisX.GridLines.MinorVisible = False diagram.AxisY.GridLines.Visible = True diagram.AxisY.GridLines.MinorVisible = True diagram.AxisY.GridLines.Color = Color.Red diagram.AxisY.GridLines.LineStyle.DashStyle = DashStyle.Solid diagram.AxisY.GridLines.LineStyle.Thickness = 2 diagram.AxisY.GridLines.MinorColor = Color.Blue diagram.AxisY.GridLines.MinorLineStyle.DashStyle = DashStyle.Dash diagram.AxisY.GridLines.MinorLineStyle.Thickness = 1 |
在下面的插图中显示了结果。
在 DevExpress Code Central 数据库中可以找到完整的示例项目,网址是 http://www.devexpress.com/example=E1367。 取决于目标平台类型 (ASP.NET、WinForms 等),可以在线运行本示例,或者下载自动可执行的示例。 |
