本示例演示了在运行时刻如何创建并定制 自定义轴标签。
// Cast the chart's diagram to the XYDiagram type, to access its axes. XYDiagram diagram = (XYDiagram)chartControl1.Diagram; // Add two custom labels to the X-axis' collection. diagram.AxisX.CustomLabels.Add(new CustomAxisLabel("Custom Label 1")); diagram.AxisX.CustomLabels.Add(new CustomAxisLabel("Custom Label 2")); // Define their AxisValue. Since the custom labels belong to the X-axis, // this property determines the series argument, to which labels should stick. diagram.AxisX.CustomLabels[0].AxisValue = "B"; diagram.AxisX.CustomLabels[1].AxisValue = "D"; // Customize the custom labels' appearance. diagram.AxisX.Label.TextColor = Color.Red; |
' Cast the chart's diagram to the XYDiagram type, to access its axes. Dim diagram As XYDiagram = CType(chartControl1.Diagram, XYDiagram) ' Add two custom labels to the X-axis' collection. diagram.AxisX.CustomLabels.Add(New CustomAxisLabel("Custom Label 1")) diagram.AxisX.CustomLabels.Add(New CustomAxisLabel("Custom Label 2")) ' Define their AxisValue. Since the custom labels belong to the X-axis, ' this property determines the series argument, to which labels should stick. diagram.AxisX.CustomLabels(0).AxisValue = "B" diagram.AxisX.CustomLabels(1).AxisValue = "D" ' Customize the custom labels' appearance. diagram.AxisX.Label.TextColor = Color.Red |
在下面的插图中显示了结果。
在 DevExpress Code Central 数据库中可以找到完整的示例项目,网址是 http://www.devexpress.com/example=E1359。 取决于目标平台类型 (ASP.NET、WinForms 等),可以在线运行本示例,或者下载自动可执行的示例。 |
