本示例演示了在运行时刻如何为图表添加 辅助轴。
using System; using System.Drawing; using System.Windows.Forms; using DevExpress.XtraCharts; // ... private void Form1_Load(object sender, EventArgs e) { // Create a new chart. ChartControl chartControl1 = new ChartControl(); // Create two series. Series series1 = new Series("Series 1", ViewType.Bar); Series series2 = new Series("Series 2", ViewType.Line); // Add points to them, with their arguments different. series1.Points.Add(new SeriesPoint("A", 10)); series1.Points.Add(new SeriesPoint("B", 12)); series1.Points.Add(new SeriesPoint("C", 17)); series1.Points.Add(new SeriesPoint("D", 14)); series2.Points.Add(new SeriesPoint("I", 1500)); series2.Points.Add(new SeriesPoint("II", 1800)); series2.Points.Add(new SeriesPoint("III", 2500)); series2.Points.Add(new SeriesPoint("IV", 3300)); // Add both series to the chart. chartControl1.Series.AddRange(new Series[] { series1, series2 }); // Hide the legend (optional). chartControl1.Legend.Visible = false; // Create two secondary axes, and add them to the chart's Diagram. SecondaryAxisX myAxisX = new SecondaryAxisX("my X-Axis"); SecondaryAxisY myAxisY = new SecondaryAxisY("my Y-Axis"); ((XYDiagram)chartControl1.Diagram).SecondaryAxesX.Add(myAxisX); ((XYDiagram)chartControl1.Diagram).SecondaryAxesY.Add(myAxisY); // Assign the series2 to the created axes. ((LineSeriesView)series2.View).AxisX = myAxisX; ((LineSeriesView)series2.View).AxisY = myAxisY; // Customize the appearance of the secondary axes (optional). myAxisX.Title.Text = "A Secondary X-Axis"; myAxisX.Title.Visible = true; myAxisX.Title.TextColor = Color.Red; myAxisX.Label.TextColor = Color.Red; myAxisX.Color = Color.Red; myAxisY.Title.Text = "A Secondary Y-Axis"; myAxisY.Title.Visible = true; myAxisY.Title.TextColor = Color.Blue; myAxisY.Label.TextColor = Color.Blue; myAxisY.Color = Color.Blue; // Add the chart to the form. chartControl1.Dock = DockStyle.Fill; this.Controls.Add(chartControl1); } |
Imports System Imports System.Drawing Imports System.Windows.Forms Imports DevExpress.XtraCharts ' ... Private Sub Form1_Load(ByVal sender As Object, ByVal e As EventArgs) _ Handles MyBase.Load ' Create a new chart. Dim chartControl1 As New ChartControl() ' Create two series. Dim series1 As New Series("Series 1", ViewType.Bar) Dim series2 As New Series("Series 2", ViewType.Line) ' Add points to them, with their arguments different. series1.Points.Add(New SeriesPoint("A", 10)) series1.Points.Add(New SeriesPoint("B", 12)) series1.Points.Add(New SeriesPoint("C", 17)) series1.Points.Add(New SeriesPoint("D", 14)) series2.Points.Add(New SeriesPoint("I", 1500)) series2.Points.Add(New SeriesPoint("II", 1800)) series2.Points.Add(New SeriesPoint("III", 2500)) series2.Points.Add(New SeriesPoint("IV", 3300)) ' Add both series to the chart. chartControl1.Series.AddRange(New Series() { series1, series2 }) ' Hide the legend (optional). chartControl1.Legend.Visible = False ' Create two secondary axes, and add them to the chart's Diagram. Dim myAxisX As New SecondaryAxisX("my X-Axis") Dim myAxisY As New SecondaryAxisY("my Y-Axis") CType(chartControl1.Diagram, XYDiagram).SecondaryAxesX.Add(myAxisX) CType(chartControl1.Diagram, XYDiagram).SecondaryAxesY.Add(myAxisY) ' Assign the series2 to the created axes. CType(series2.View, LineSeriesView).AxisX = myAxisX CType(series2.View, LineSeriesView).AxisY = myAxisY ' Customize the appearance of the secondary axes (optional). myAxisX.Title.Text = "A Secondary X-Axis" myAxisX.Title.Visible = True myAxisX.Title.TextColor = Color.Red myAxisX.Label.TextColor = Color.Red myAxisX.Color = Color.Red myAxisY.Title.Text = "A Secondary Y-Axis" myAxisY.Title.Visible = True myAxisY.Title.TextColor = Color.Blue myAxisY.Label.TextColor = Color.Blue myAxisY.Color = Color.Blue ' Add the chart to the form. chartControl1.Dock = DockStyle.Fill Me.Controls.Add(chartControl1) End Sub |
在下面的插图中显示了结果。
在 DevExpress Code Central 数据库中可以找到完整的示例项目,网址是 http://www.devexpress.com/example=E1244。 取决于目标平台类型 (ASP.NET、WinForms 等),可以在线运行本示例,或者下载自动可执行的示例。 |
