本示例演示了在运行时刻如何创建并定制 常数线。
因为常数线从属于图像的 轴,因此首先需要把 图象 对象转换为适当的图象类型。 此后,就可以访问轴,并管理它们的常数线集合。
// Cast the chart's diagram to the XYDiagram type, to access its axes. XYDiagram diagram = (XYDiagram)chartControl1.Diagram; // Create a constant line. ConstantLine constantLine1 = new ConstantLine("Constant Line 1"); diagram.AxisY.ConstantLines.Add(constantLine1); // Define its axis value. constantLine1.AxisValue = 7; // Customize the behavior of the constant line. constantLine1.Visible = true; constantLine1.ShowInLegend = true; constantLine1.LegendText = "Some Threshold"; constantLine1.ShowBehind = false; // Customize the constant line's title. constantLine1.Title.Visible = true; constantLine1.Title.Text = "Constant Line Title"; constantLine1.Title.TextColor = Color.Red; constantLine1.Title.Antialiasing = false; constantLine1.Title.Font = new Font("Tahoma", 14, FontStyle.Bold); constantLine1.Title.ShowBelowLine = true; constantLine1.Title.Alignment = ConstantLineTitleAlignment.Far; // Customize the appearance of the constant line. constantLine1.Color = Color.Red; constantLine1.LineStyle.DashStyle = DashStyle.Dash; constantLine1.LineStyle.Thickness = 2; |
' Cast the chart's diagram to the XYDiagram type, to access its axes. Dim diagram As XYDiagram = CType(chartControl1.Diagram, XYDiagram) ' Create a constant line. Dim constantLine1 As New ConstantLine("Constant Line 1") diagram.AxisY.ConstantLines.Add(constantLine1) ' Define its axis value. constantLine1.AxisValue = 7 ' Customize the behavior of the constant line. constantLine1.Visible = True constantLine1.ShowInLegend = True constantLine1.LegendText = "Some Threshold" constantLine1.ShowBehind = False ' Customize the constant line's title. constantLine1.Title.Visible = True constantLine1.Title.Text = "Constant Line Title" constantLine1.Title.TextColor = Color.Red constantLine1.Title.Antialiasing = False constantLine1.Title.Font = New Font("Tahoma", 14, FontStyle.Bold) constantLine1.Title.ShowBelowLine = True constantLine1.Title.Alignment = ConstantLineTitleAlignment.Far ' Customize the appearance of the constant line. constantLine1.Color = Color.Red constantLine1.LineStyle.DashStyle = DashStyle.Dash constantLine1.LineStyle.Thickness = 2 |
在下面的插图中显示了结果。
在 DevExpress Code Central 数据库中可以找到完整的示例项目,网址是 http://www.devexpress.com/example=E1370。 取决于目标平台类型 (ASP.NET、WinForms 等),可以在线运行本示例,或者下载自动可执行的示例。 |
