这个示例展示了如何把自定义控件添加到最终用户设计器的 工具箱 中 。
要这样做,则接管 XRDesignMdiController.DesignPanelLoaded 事件处理程序,然后把所需的项添加到工具箱中。
要使本示例能正确工作,则 XtraReport1 子类(派生于 XtraReport 类) 应该存在于示例应用程序中。
using System; using System.Windows.Forms; using System.Drawing.Design; using DevExpress.XtraReports.UI; using DevExpress.XtraReports.UserDesigner; // ... private void button1_Click(object sender, EventArgs e) { // Create an End-User Designer form. XRDesignForm designForm = new XRDesignForm(); // Handle the DesignPanelLoaded event. designForm.DesignMdiController.DesignPanelLoaded += new DesignerLoadedEventHandler(DesignMdiController_DesignPanelLoaded); // Load a report into the Designer. designForm.OpenReport(new XtraReport1()); // Show the End-User Designer form, modally. designForm.ShowDialog(); } void DesignMdiController_DesignPanelLoaded(object sender, DesignerLoadedEventArgs e) { // Get the Toolbox service from the Designer host. IToolboxService ts = (IToolboxService)e.DesignerHost.GetService(typeof(IToolboxService)); // Add a new category to the Toolbox, // and place a custom control into it. ts.AddToolboxItem(new ToolboxItem(typeof(MyControl)), "New Category"); } // A custom control. public class MyControl : XRControl { // ... } |
Imports System Imports System.Windows.Forms Imports System.Drawing.Design Imports DevExpress.XtraReports.UI Imports DevExpress.XtraReports.UserDesigner ' ... Private Sub button1_Click(ByVal sender As Object, _ ByVal e As EventArgs) Handles button1.Click ' Create an End-User Designer form. Dim designForm As New XRDesignForm() ' Handle the DesignPanelLoaded event. AddHandler designForm.DesignMdiController.DesignPanelLoaded, _ AddressOf DesignMdiController_DesignPanelLoaded ' Load a report into the Designer. designForm.OpenReport(New XtraReport1()) ' Show the End-User Designer form, modally. designForm.ShowDialog() End Sub Private Sub DesignMdiController_DesignPanelLoaded(ByVal sender As Object, _ ByVal e As DesignerLoadedEventArgs) ' Get the Toolbox service from the Designer host. Dim ts As IToolboxService = _ CType(e.DesignerHost.GetService(GetType(IToolboxService)), IToolboxService) ' Add a new category to the Toolbox, ' and place a custom control into it. ts.AddToolboxItem(New ToolboxItem(GetType(MyControl)), "New Category") End Sub ' A custom control. Public Class MyControl Inherits XRControl ' ... End Class |
注意,当控件被添加、而没有指定类别时,它被放置在标准控件中。
或者,如果指定了类别,那么自定义控件将被独立显示。
