这个示例展示了如何使用 XRDesignForm 类,来把报表加载到 最终用户报表设计器 窗体中。
为了把报表指派到设计器窗体,使用了 XRDesignForm.OpenReport 方法。 同时,XRDesignForm.SetWindowVisibility 方法隐藏了所创建设计器窗体中的 Field List(字段列表) 和 属性网格 设计停靠面板。
using System; using System.Windows.Forms; using DevExpress.XtraReports.UI; using DevExpress.XtraReports.UserDesigner; // ... private void button1_Click(object sender, EventArgs e) { // Create a design form. XRDesignForm designForm = new XRDesignForm(); // Open the report to edit. designForm.OpenReport(new XtraReport1()); // Hide the Field List and Property Grid dock panels. designForm.SetWindowVisibility(DesignDockPanelType.FieldList | DesignDockPanelType.PropertyGrid, false); // Invoke the design form. designForm.Show(); } |
Imports System Imports System.Windows.Forms Imports DevExpress.XtraReports.UI Imports DevExpress.XtraReports.UserDesigner ' ... Private Sub OnButtonClick(ByVal sender As System.Object, _ ByVal e As System.EventArgs) Handles Button1.Click ' Create a design form. Dim DesignForm As New XRDesignForm() ' Open the report to edit. DesignForm.OpenReport(New XtraReport1()) ' Hide the Field List and Property Grid dock panels. DesignForm.SetWindowVisibility(DesignDockPanelType.FieldList Or _ DesignDockPanelType.PropertyGrid, False) ' Invoke the design form. DesignForm.Show() End Sub |
